knock
Ajuste práctico independiente
2509 Vistas
using a wide band afr on the road can also using knock sensor for the tuning?
You can use knock sensing to make sure that the engine isn't knocking when adding timing, and also, if it is setup correctly, to take timing out for engine protection if knock does occur.
thank you
