Lambda sensor
Ajuste práctico independiente
Módulo correspondiente: Ejemplos resueltos > AEM Infinity > Paso 1: Configuración y prueba de la ECU
1518 Vistas
Hello ,
When i go to input function assignments for the lambda 1 input , i double click , they say to select lambda 3 to use signal from sensor, but when i need to choose the input , it only propose Analogs ( originally analog 11 ) witch i wired to the EGT sensor. On the manual the lambda have it's proper wiring pins. I dont understand.
Thanks you !
Ok seems like i need to put onboard and dont put the lambda 3 :)
