Link4 can Wideband Lambda
Ajuste práctico independiente
2969 Vistas
Hi. I got LinkG4+ ecu on R33 gtst and cant get Link4 wideband Lamda to work.
Ecu is finding it in can setup but i cant get any readings of it when I start the car... Its probably some settings that I missed ... Can you guys help me with that?
how confident are you in the can wiring? Terminating resistors, CAN Hi/Lo swapped are common problems when things don't seem to work at all.
If you put a data log up we can see what lambda codes are showing.
