megasquirt
Ajuste práctico independiente
2198 Vistas
Hello good night, I have a question, when you start doing the injection table and ignition, the ego control must be deactivated, right? and when the tables are drawn does the ego control reactivate?
I am referring to the lambda control, if you have to disable it so that it does not interfere with the tuning of the tables.
i use the ego to tune the ve, i set 25%. then i datalog it driving.
so i see the datalog and adjust where it atuates
