miata tuning trigger input
Ajuste práctico independiente
Módulo correspondiente: Ejemplos resueltos > MegaSquirt MS3Pro > Paso 2: Configuración del disparador
2199 Vistas
do the 1.6 miata and the 1.8 share trigger input like the 1.6 and the 4g63?
Your question is not very clear, but if you are asking if the B6 1.6 engine and the BP 1.8 engine from the NA miata share the same trigger pattern, then the answer is yes.
