potable knock sensor
Ajuste práctico independiente
2008 Vistas
can you recomend which one potable knock sensor is easy to use & install but i wan also can moniter AFR, RPM, BOOSE.
The Tuner Nerd Knock Monitor is the only product I'm aware of that can monitor boost and AFR inputs as well as knock. It's a little more involved to setup than the likes of the Link G4+ knock block or Plex Knock Monitor but does work well.
