SR20DET no spark while cranking
Ajuste práctico independiente
1264 Vistas
Hey there,
first of all, i already learned alot from HPAcademy but i have problem with the engine of my brother. It´s a Nissan Silvia S14A (LHD) with SR20DET.
I´m having trouble to get spark while cranking, normally testing outputs everything is fine. The engine is bone stock with a 5-0 Ignite V3 trigger setup and an EMU Classic ECU. I wired the trigger 1 signal directly between ecu and the PNP adapter because it somehow went with the PNP adapter to ignition coil#5
If anyone can help me find the problem i have i would be thankful! The car should go to an event in 1 month..
Best greets from Germany, i attached the map below
