Trigger setup WRX Impreza
Ajuste práctico independiente
3857 Vistas
Hello!
I still can't understand how to configure my own Subaru camshaft trigger.
I have Ecu Master Classic and on engine is 36-2-2-2 crank trigger and 2-tooth camshaft trigger
What trigger type I need to use and settings to synchronising it?
Car:
Subaru Impreza wrx 2004
EJ25 engine without variable valve timing
have you read this ? or contacted the ecu master tech support im sorry i am personally not familiar with their trigger setup procedure
https://www.ecumaster.com/wp/wp-content/uploads/2016/11/emu_manual.pdfted
Yes, I readed manual.
I just now wrote to tech support then will I see what they answer.
look like triggers don't show correct.
