Tuner studio Lambda1 Target gauge
Ajuste práctico independiente
Módulo correspondiente: Ejemplos resueltos > MegaSquirt MS3Pro > Paso 7: Ajuste del combustible en estado estable
1367 Vistas
How do you set up a lambda1 target gauge on the tuner studio dashboard?
Found some info...
thank you!
I didn't know about Add Custom Channel Wizard.
I tried it right away.
I haven't put it on the car and run it yet, but I think I was able to display the target AFR lambda.
thanks so much.
I am Japanese.
With gratitude from Japan.
-- Google Translation --
どういたしまして
