Water/meth injection
Ajuste práctico independiente
2453 Vistas
Should a water/meth injector be installed pre air temp sensor? Side question pre throttle body?
Cheers
Hello yes this is the preferred method i have used over the years i normally try and have a bit of a gap between the two as to stop the wetting of the sensor as much as possible
