Hi everyone,
I'm working on a calibration for a VQ35DE engine equipped with aftermarket headers and an upgraded air filter element.
Since the volumetric efficiency has changed due to the breathing mods, I'm planning to make a small and safe adjustment to the intake VVT maps—specifically adding around a 3-degree advance in the lower-to-mid RPM range to improve low-end torque and throttle response.
I would love to get some insights from experienced tuners here:
What is the best approach or formula when calculating VVT adjustments on a VQ35DE Hitachi ECU after installing headers?
Are there specific load/RPM cells where I should be careful not to over-advance to avoid negative valve overlap or loss of dynamic compression?
Any tips or recommended strategies for a clean VVT calibration on these VQ setups would be greatly appreciated. Thanks!
The process to tuning VVT on any engine remains virtually the same as Andre has explained in one of the tuning fundamental videos (I cant recall exactly which). It is a difficult process to carry out correctly without a dyno. You do full ramp runs at static amounts of VVT adjustment and then use the best bits from every run. Without a dyno you can use measurements such as VE change/AFR change but its not nearly as scientific.
