GTX4088R for 1FZFE
3245 Vistas
Hi
i plan to upgrade landcruiser 100 with 1FZFE engine to Turbo Charger, plan has 2 phase
it already have Haltech 750 and stage 1 Kelford cams and bigger theotrle body(from 70mm to 90mm)
Phase1: with stock internal to have about 12psi boost to have about 400whp and Phase2: to have about 25psi with upgrade internal.
This car is daily drive and long distance traveling and some times desert dune offroading “NOT A RACE CAR”
I need low and medium power
with Boost Advise software made by Garret and help of Borgwarner match bot, I saw the GTX4088R is suitable, can you advise am I right?
then there is 0.86, 0.95 and 1.06 Turbine AR
is the compressor unit is correct?
if yes can you help me which Turbine AR use as I said the safty and dueablity in long distance travels is important.
tnx
If you need low and mid range revs power go with something smaller than gtx4088. I would try Mamba turbo gtx3584 for 75 lbs or equivalent. You do not want to install such a big turbo not planning to use the full potential power.
The smaller the AR the earlier turbo will spool up ( which is what you need fir a heavy truck driving on the streets). However, if you choose the small AR it will effect you fuel economy when driving outside of city because the engine will be most likely seeing boost all time in cruise mode. So you will need to make a priority first - drivability on the streets or fuel economy in cruise mode.
