Knock Limit Tables
944 Vistas
How do you extrapolate a NA Knock Limit Table for Supercharger Boost? I don't see this explained anywhere.
The Tables are tied together, as in they all share the same table and axis of Load by Mbar/Psi, and RPM.
I see nothing regarding this in any of the videos I've watched. I'm not even sure how it works, except
that it's used in the calculation on what it chooses for Final Ignition so if I set it to conservative I'm going
to be clamping my ignition to it all the time. I also don't want it too weak that it isn't protective.
Hello Steven
Personally, I would not even dare to think about extrapolating a knock control map.”
See attached picture
but your forced to........ So I'm confused. You can't add columns, you can't change a Table's Column Axis by itself.
You change one Table's Axis, it changes them all.
Should I just change the Axis into Boost, and leave the Knock Control Table itself as-is?
Then all the Values don't line up in the correct Mbar Columns they were before, and there is no PSI values unless you make your own.
the Cells would not line up in the same NA Column values this way, and would be in entirely different
areas if its using the value in the AXIS to reference.
