Hey,
i am just Starting i hope its ok to question this here.
if the Injector angle goes higher like to 340 degree does that mean as higher it goes as open is the Injector?
Does the Fuel rail pressure should stay the same high if you at WOT? as higher my angle goes the Fuel pressure drops, that should not happen or?
Thanks
