EMU Black Acceleration Help!
My car is having an acceleration issue after the 3rd drift event. After looking over the data log, the moments I attempt to accelerate and replicate the problem its seems as if my injectors are not spraying enough when looking at Injector PW in comparing when its working properly. The other thing that really throws me off is that it progressively gets worse, choking and hesitating, to where I need to barely apply throttle in order to slowly accelerate and once that happens I turn the car off and on the problem goes away, only come back within minutes. Emailed ECU masters and they led me into the direction of ACC Enrichments. I'm just confused because I never messed with it to begin with but I have heard that the Ecu attempts to tweak itself but I'm honestly lost.
-Replaced o2 sensors
-Verified FPR
The two images included show the comparison of when I'm on WOT and the car is not accelerating, you can see the Injector PW is really low for being WOT and AFR numbers are super lean. On the other image, perfect values.
