Aeromotive 10 gallon brushless fuel pump current draw (A)
Aerodynamics Fundamentals
Discussion and questions related to the course Aerodynamics Fundamentals.
Does anyone know how much amps does this pumps draws?
Aeromotive doesn't have any datasheet specifying that.
https://aeromotiveinc.com/products/10-0-gpm-brushless-spur-gear-fuel-pump-with-true-variable-speed-control-in-line?srsltid=AfmBOopcrS0jniGnQoBg2bEx-HD5weC_-maRAxarT8ed9_hPvj0AfqjK
It only says the following in the user manual:
60A fuse and 6 AWG wire. Is that it? Or its oversized?
At that level, you should be talking with the engineering support folks at Aeromotive. It seems like it's a positive displacement pump, so it probably really can draw 60A transient when feeding a -12 line at 150 psi. What a beast!
