EMU PMU16 - Thermistor issue
Aerodynamics Fundamentals
Discussion and questions related to the course Aerodynamics Fundamentals.
Hi all - hope to find some help here.
I want to integate a BOSCH 4 bar MAP and temp sensor to the PMU16 - should be an easy straight forward thing.
However, I dont get the temp sensor to read the correct value. I do use the wizard to give him the calibration of the BOSCH Temp sensor. But it will always read 250°C (while having 20°C) in the room because it keeps referring to voltage instead of resistance. I know the wizard tranfers resistance to voltage but keeps reading 0V whichis equal around 250°C - which is wrong.
Do I miss something here with pullup ?
Found issue - you have to set the 10k pullup twice. One in the main menu of the Input and one in the wizard...
Good find Philipp,
This will be helpful for anyone who is having these issues in the future.
