Sr20ve crankshaft which is better?
Aerodynamics Fundamentals
Discussion and questions related to the course Aerodynamics Fundamentals.
Hi. Ive been building an all motor sr20ve and been wondering which crankshaft is good for power? Or maybe reliability too. The 8 counterweight or the 4 counterweight?
The stock Nissan crankshaft for the SR20 is a full counterweight crankshaft with 8 counterweights? It really depends what your power aims are as to whether the factory crank will suffice. There's plenty of people who have made 800-1000 hp on a stock crank in drag applications but for reliability you may be better to consider a billet crank at that sort of power level. If you're looking at 600 hp or below then there should be no need to replace a good condition stock crank.
