Hi, about the Understeer sheet: with mid corner section is the yes / no around the right way ? I would have thought that for excessive roll you would increase spring / anti roll bar rate and vice versa.
For the Oversteer sheet: For excessive rear roll would you not increase rear spring / ant roll bar rate ?
Just wondering if there are typos on the sheet.
Cheers.
Hi John, thanks for spotting that. It looks like the incorrect version got uploaded by accident. I'll get it sorted as soon as we're back on deck!
Have these sheets been updated? I have still see the confusing guidelines for addressing the mid corner understeer and oversteer in these cheat sheets. Also, I think the yes and no to the question of "Does the rear bottom out?" is possibly switched. I imagine you would increase rear spring rate if it was bottoming out, right?
Hi Andre Simon,
Have these sheets been updated? I was checking here and it seems that they are still incorrect.
Hey team, we've created a new Wheel Alignment Tips attachment for the course.
It's a different format and hopefully adds a little more detail and context than the previous option so you can diagnose and tune your handling with a combination of alignment and suspension setup options.
Download it below and let us know what you think.
Cheers, Sam
