hello all. I'm in the process of building a S1 xr6 non vct AU(Intech 4ltr) and am using these courses to assist me with basic building fundamentals. The plan at this stage, I want to turbo the motor I have in the car and be able to pull the bare block out once built one is ready and just bolt up all the manis/bolt ons etc. so I'm looking for recommendations on turbos that I'm able to run on a factory set up(lowish power) but be capable of running 400-500ish hp for when I swap motors around, I was looking at the GT3282R as I believe that's factory turbo for Barras. I have ecu/wiring sorted via a guy in aus who specializes in ford performance wiring. I'm down to see other peoples build specs and advice for my journey into my first built motor done by myself. side note I am wanting to keep the car running while I take my time to build this motor so I'm still able to have fun in the car and get seat time. cheers guys
Hi Kaleb the std barra turbo is perfect for what you are wanting and will perform well in a streetcar
Regards Ross
