A place to buy, sell and swap HPA course-relevant equipment and supplies. Tuning widgets, wiring apparatus, engine building gizmos, fabrication gear, alignment thingamajigs and more welcome.
Hello fellow tuners, I’m currently looking at purchasing my first dyno. I’ve been tuning since 2018. Mainly on the street, occasional I’ll rent out a dynojet 224X. Main cars I deal with are Honda’s, 240s, JZ swapped cars, and looking at getting into the Ls platform. All the tunes I do are all sidework. Also help customers build, and get there car setup correctly. From swaps, turbo kits etc.. So the main thing I need help with, is finding a place I would be able to get a dyno setup. I don’t need a lot of room at first, I’m just trying to get started. I have a decent clientele, I have a good name. Just trying to take it to the next step. My next question is, can I find a decent budget roller dyno? I see dynamites for 10k (I’m located in the US) I’ve never been a fan of cheaper products. Since I don’t have financial support, I’m just trying to find a way to make something happen. I would love a dynojet 224X. It’s just finances. Mainly looking for a used one. I don’t have a business license yet, but I can look into one to get a business Loan if needed. Hopefully some of you guys have gone through my same struggle!
Dynojet 24" roll is the cheapest I've seen work properly/reliably from a power readout point of view. Without load control you are a bit limited, but it's still so much more data than not having a dyno.
Mustang 500 would be my budget choice with load control.
If you want to run big power stuff, then I'd look at Mainline.
Without calling out specific brands, if a tool doesn't give you accurate info, it's not really a tool.
Worse, you can work around inaccurate, as you're going to be doing mostly comparative work - except for those who are overly focussed on "horsepower" numbers, and not what the vehicle actually does, BUT you must have a dyno' that is consistent from one run to the next to the one next month, so you KNOW exactly what the changes did, relative to the original.
