A place to buy, sell and swap HPA course-relevant equipment and supplies. Tuning widgets, wiring apparatus, engine building gizmos, fabrication gear, alignment thingamajigs and more welcome.
This is my first build: a 1999 Corvette. I'm in Utah, but I built and tuned this car about 3 years ago in Oklahoma. I wanted to transform this older Corvette into a modern, naturally aspirated sports car. After building the engine, I tuned it myself (stock ECU) because I could not find any tuners in the area that could provide good torque and power while still retaining OBD II emissions compliance as well as a stable idle and a smooth ride at low rpm cruise.
This is the Corvette before I started the disassembly:
· Naturally Aspirated GM LS3 Engine:
o ARP Fasteners (bolts, studs, and nuts)
o Felpro Gasket/Seal Kit
o Callies Billet 24 Tooth GM Reluctor Wheel
o Timing Sprocket Gear
o Valvetrain:
§ Cam Motion Custom LS3 Camshaft
· 226°/240° | 0.605"/0.588" | LSA 112°+4°
§ Hardened rocker trunnions with C932 bushings
§ PAC Racing .660” lift dual valve springs
§ Morel link bar hydraulic roller lifters
§ SAE 4130 pushrods case hardened to 60 HRC
o C6 Engine Mounts
o Wiring & Emissions:
§ Caspers Wire Harnesses for LS3 Conversion
§ Re-pin fuel injector connectors — EV1 to EV6
§ C6 EVAP Purge Solenoid & Bracket
§ C6 PCV Tube
§ C6 Intake Fitting
§ C6 Fuel Vaper Line
§ Elite Engineering E2 PCV Oil Catch Can
o Air Intake:
§ 90mm LS2 Throttle Body
§ Halltech C5 Killer Bee™ II Induction Package
§ LS7 MAF/IAT Sensor
· Exhaust:
o Kooks 1-7/8” Headers and catted 3” X-Pipe
· C6 Z51 (RPO J55) Brake Package:
o Caliper brackets, pads, and rotors
§ 13.4” front rotors | 12.9” rear rotors
· Drivetrain:
o LS7 Clutch & Hydraulic Package
o C6 Shifter
o HPI Differential Brace
o Texas Drivetrain Performance:
§ 300 Maraging Steel Output Shafts
§ T56 Rebuild — 3/4 steel shift fork, triple cone synchronizers, 30-spline mainshaft
§ Differential — 3.90:1 Motive Performance ring & pinion, seal kit, 30-spline pinion, bearings
· Steering & Suspension:
o Turn One Steering Pump and Pulley
o Bilstein B6 Performance Shocks
o Hotchkis Sport Suspension Anti-Sway Bars
o Lexani L-CC7 Wheels
§ 18x9.5 front | 19x11 rear
o Continental ExtremeContact Tires
§ 255/40ZR18 front | 295/35/19 rear
· Kenwood DNX697S Double Din Radio:
o Rear View Camera, Bluetooth, and Garmin GPS
· EFI Tuning — self tuned with HP Tuners
o TAC Module — improve throttle response
o Fuel Flow:
§ Set injector control to match the LS3 injectors
§ Set power enrichment for safe WOT
o Idle — establish smooth idle without stall
o Establish Stoichiometric AFR:
§ Volumetric Efficiency and MAF sensor calibration
o Closed Loop Fuel Trims — O2 sensor calibration
Spark Advance — optimize for 91 octane pump gas
This is Corvette after I completed my build and moved to Utah:
The following images show my hard work in my garage.
RADIO SWAP
· Replace center bezel, solder wiring, install double DIN receiver.
· Add backup camera and run wiring behind body panels and through existing gromet in the firewall.
ENGINE SWAP — replace stock LS1 with the modified LS3
· Remove hood, bumper cover, condenser, radiator, intake, exhaust, ABS module, PCM, shocks, etc.
· Separate fuel and EVAP lines, wire harness connectors, etc.
· Separate drivetrain from chassis and support on tires.
· Separate LS1 engine from drivetrain and remove from front cradle (engine sold & shipped)
· Disassemble drivetrain to send out transmission and differential for upgrades (30-spline & 3.90:1 ratio)
LS3 UPGRADE — camshaft, valvesprings, pushrods, and rocker arm trunnion
· Disassemble engine and swap cam sprocket (4-probe to single-probe)
· Send crankshaft out for reluctor wheel swap (58-tooth to 24-tooth)
· Valvetrain Upgrade — install guides, springs, locks, and retainers
· Engine Reassembly — crankshaft, main bearing caps, rod caps (stretched rod bolts)
· Replace stock camshaft — more duration, lift, and overlap; advance to maintain dynamic compression
· Install front/rear covers and seals, windage tray, oil pan, lifters, and pushrods
· Replace rocker roller bearings with bushings, trunnions, and snap rings
· Complete engine assembly and prime with oil
DRIVETRAIN REASSEMBLY
· Replace engine mount brackets with C6 brackets to accommodate LS3 block boss with hole
· Modify C6 engine mount brackets — drill ¼” diameter blind hole for engine mount dowel
· Install LS3 engine onto front cradle
· Mount new LS7 clutch kit — flywheel, clutch disc, pressure plate, slave cylinder, and throw-out bearing
· Modify clutch pedal assembly to accommodate master cylinder upgrade
· Replace stock shifter with C6 shifter
· Attach aftermarket brace to differential — reduce powertrain shake
· Mount differential and transmission to rear cradle
· Insert rear axles into differential
· Assemble drivetrain — torque tube to engine and transmission/differential to torque tube
WIRING
· Install and connect wire harnesses to sensors and actuators
· Re-pin fuel injector connectors — replace stock Minitimer (Bosch EV1) with USCAR (Bosch EV6)
INSTALL NEW ENGINE ACCESSORIES AND SENSORS
· Replace steering components — pump, pulley, hoses, and cooler lines
· Replace belt tensioners, idler pulleys, and belts — both drive and A/C belts
· Relocate and/or replace solenoids and sensors — EVAP purge, EOP, CKP
· Add wire harness adapters — CMP, MAP, EVAP purge, TP, TAC, and knock sensors
FINAL ASSEMBLY
· Complete main assembly — drivetrain to chassis, brake lines, fuel lines, emissions, wiring, cooling, etc.
· Upgrade induction with LS7 MAF/IAT sensor and larger duct to accommodate 90mm LS2 throttle body
· Add PCV oil catch can system (emissions compliant closed system)
SUSPENSION & BRAKE UPGRADE
· Replace shocks with aftermarket performance shocks
· Replace anti-sway bars with 1-1/4” front and 1” rear bars (1/4” increase over stock)
· Swap front and rear caliper brackets with C6 Z51 brackets to accommodate Z51 brake package
· Add Z51 brake pads and larger Z51 rotors
· Replace rear wheel bearing and hub assemblies
· Adjust parking brake star wheel to spread brake shoes appropriately
· Add new wheels and tires (255/40R18 front, 295/35R19 rear) with rear wheel spacers
EXHAUST UPGRADE
· Remove stock manifold and mid-pipe
· Add stock O2 sensors to collectors and wideband O2 sensor to passenger side collector
· Install new 1-7/8” headers and 3” catted X-pipe — sent out for coating after verifying install/fitment
WHEEL/TIRE ALIGNMENT
· Adjust front and rear camber, thrust angle, rear toe, and front toe
PREPARE FOR THE ROAD
· Add fluids — engine coolant and oil, brake and clutch fluid
· Bleed brakes and clutch
· Charge A/C system
· Speedometer calibration — calculate and change the VSS calibration for final ratio and tire size
· Engine Break-In — follow GM guidelines for rpm and engine load limits as well as piston ring seating procedures
EFI ENGINE CALIBRATION
I developed mathematical formulas to establish smooth 2D curves and 3D maps and used Excel VBA to generate tables from my formulas where I copied the values into the HP Tuners VCM Editor, thereby allowing me to transform the stock LS1 tune into my custom tune for the modified LS3.
Ø I calibrated ("tuned") my engine for 91-octane E10 pump gasoline
TAC MODULE — improve throttle response
· Increase throttle area by 20% in the mid and upper range accelerator pedal position
· Smooth out the “Desired Pedal Area vs. Pedal Position” curve
FUEL FLOW — tune injector control to match the LS3 injectors
· Injector Offset — interpolate offset/voltage/vacuum from stock 2013 (C6) Corvette
· Increase flow rate vs. vacuum to accurately control the EV6/USCAR 42 lb/hr @ 58 psi injectors
· Modify EQ (equivalence ratio) table to target 12.05:1 AFR (air to fuel ratio) during power enrichment
IDLE — establish smooth idle without stall
· Set ETC Area Scalar appropriately to the 90mm throttle body
· Add 25 rpm and 60% more airflow to accommodate Stage 2 camshaft
· Adaptive Idle — adjust PID controls and overspeed/underspeed idle spark advance
VOLUMETRIC EFFICIENCY — establish Stoichiometric AFR (air to fuel ratio)
· Install and set-up wideband O2 sensor
· Disable MAF (mass airflow) sensor and closed loop operations
· Conduct open loop test drives at part throttle and low rpm, followed by WOT (wide open throttle)
· Use wideband data to modify VE (volumetric efficiency) values — establish ≤ ±5% AFR variance
MASS AIRFLOW CURVE — establish Stoichiometric AFR
· Enable MAF sensor to entire rpm range
· Use wideband data to modify part throttle frequency values — establish ≤ ±5% AFR variance
· Conduct aggressive drives up to 7000 rpm and 95 kPa MAP — establish ≤ ±5% AFR variance
CLOSED LOOP FUEL TRIMS — O2 sensor calibration
· Conduct part-throttle test drives — analyze narrowband O2 sensor voltage readings
· Calibrate O2 sensor voltages to appropriate air flow mode settings
· Enable closed loop operations and STFT and LTFT (short and long-term fuel trims)
· Verify ≤ ±5% long term and short-term fuel trim variance
SPARK ADVANCE
· Compare and analyze “Main Spark Advance” tables from stock 1999 Corvette (LS1), 2013 Corvette (LS3), and 2010 Corvette Z06 (LS7)
· Consider variables affecting flame speed including ignition lag, bore diameter, piston speed, dynamic compression ratio, airflow turbulence (i.e., air/fuel mixing), engine load, etc.
· Develop custom formulas associated with flame speed variables to create spark advance maps
· Conduct test drives and adjust values for Stage 2 camshaft — remove low rpm “bucking” and improve street drivability
CHASSIS DYNAMOMETER RENTAL
· Adjust power enrichment to maximize torque without compromising combustion chamber temps
· Adjust spark advance to maximize torque while avoiding pre-ignition and detonation
· Adjustment results @ WOT — 10 ft-lb increase and 15 hp increase
· Ensure engine protection after dyno runs — retard spark advance by 3° – 4° (depending on engine load) and increase power enrichment by 3%
· Measure and record values after final adjustments
TORQUE/POWER CURVES — STOCK LS1 VS. STOCK LS3 VS. MODIFIED LS3
· Peak wheel torque increased — 12% over stock C6 LS3 | 36% over stock C5 LS1
· Average wheel power increased — 15% over stock C6 LS3 | 43% over stock C5 LS1
That's pretty comprehensive. Nice!
