Hi Rudd,
I'm curious about your CP3 pump, my application is an M57TU2, it is fitted standard with the CP3S3/R70/20-89S pump and a common upgrade path is to an R90 pump I have been looking at "frankinstining" a pump eg something like an R110/30-89s and adapting it to suite But I am weary of the timing chain in these engines as I'm told that going to large on the pump will cause chain breakage! do you have any thoughts on this or experience with this engine?
Warren
Competition is good. Last year we where dominating qualification by over a second a lap with the D26E6A+ engine. This year we have two D26E6A+ engines in the UK truck race field and lucky also a Iveco Euro6 engine that in all are a little over 0.3 seconds apart from 1e to 3e place so great for the sport. MAN still can not follow al do they tray but all I seen so far is more smoke from them and the ones that run there B engines with the CP3 pump are now really down on power. Must say 3 out of the 5 D26 engines I build are B versions as well also struggle to dial in max fuel but think for next year the budged will be there to upgrade to a CP9 fuelpump with plenty of fuel.
We also run some test on injectors and from a performance standpoint neutral but get more smoke so now we know the engine set-up that will perform clean.
Looks like for next year I have to build a Baldur DID1 CAT ECM for a C12 race engine only problem is it run on a BOSCH ECU and do not have the pin out of the ECU and workload is killing me to make a plug and play wire loom for this engine this year. C12 use to be a A division engine now able to run in B division but still fun to find out if we can up the general performance a bit with the things we know today.
Bit more inside on Truck Racing.
Hard work keeping these Truck Race engine up and running performing to the max.
In 2021 we introduced the first D26E6A+ race engine winning the UK championship and this year we have two D26E6A+ race engines running the UK A division championship holding 1e and 2e in the championship so far but as expected the power game is on with the completion and for those that run the B type engines now in general struggle as the CP3 pumps are unable to deliver the fuel to support the power output so maybe for next year we will build and upgrade some more and have all ready to support the upgrade as it can take more than just an engine to make a race truck faster as result often come better working with the teams thinking outside the box.
Yes we did test last race weekend with a neutral result making a bit more smoke on normal diesel fuel but we have data to take things forward so it can be that HVO or GTL fuel will give the better result with the test we done reducing emissions. If you stand for something you better do it making good clean engine power is a goal and it dos not make my work easy but I like a challenge.
Torque control mapping seems to be a hot item on petrol engines now but you just need to know we and that’s the world of car/truck engine production went to drive by wire to get more control on engine performance in relation to car stability systems like ABS traction and collision control so nothing new in the real world of a daily drive and just a hype in motor sport development for some.
This is what Torque control mapping dos on a 5300Kg race truck with 5500Nm and over 1100Hp on a stop and go. Link down below. Also credit to the driver for constant shifting up the gears keeping the RPM down @ low speed maximising the RPM range as these engines easy makes full boost and Torque from 1250Rpm onwards spinning the tyres if no Torque limit is set.
www.youtube.com/shorts/263rkSMWmDU
Great CAT engines make great power but you only be able to harvest this power by using a great Baldur CAT ECM. Credit to Danny Sammons our local dealer in the US for supporting this project.
[url=http://www.youtube.com/watch?v=WzXgPi-X1vk]www.youtube.com/watch?v=WzXgPi-X1vk
Murphy’s Law Peterbilt 2000 series V8 MTU Commonrail engine. Team wouldn't live up to its name if all went well. End of run Turbo Damage but a lot of progress in power with the Mercedes MTU V8 Common Rail engine.
The CP9 Common rail fuel system on this engine certainly has potential, but it sometimes takes a bit of searching for a team to install the fuel supply and return in the right way, sometimes it also takes a while, it is possible that a control valve remains stuck after two years of not running the engine due to Covid. And when that was fixed look further and look at the data from the engine management and eventually change the fuel return from the pump and then tightly regulate its fuel pressure. This team itself also has a number of young people who want to learn to understand this modern diesel injection technique and who can simply take steps by looking at data and working with it and ask me questions if necessary and that way you always come step by step and move on making power power.
[url=http://www.youtube.com/watch?v=3bLH_H_ba0M]www.youtube.com/watch?v=3bLH_H_ba0M
Comming up AFR readings on last generation (race) engine. How low can you go? Stay tuned!
Last week testing the new Scania Race truck #PredatorMINNA @ Most race circuit.
Happy with the engine now able to use the power potential of this last Gen Scania 13L XPI Euro6 engine with our the new developed fuel system offering more fuel and stability to the fuel delivery having to put in some afford to get back drivability as the torque response from this engine is massive and we had to calm this down a bit as track conditions not always needs a power happy engine but yes that’s luxury I think.
Are we ready? Nope still loads of things to do and one of them is getting the same reading for some sensors so we can compare data to the previous generation engine we build.
Perfect dos not exist so we keep developing.
Also tested close loop Lambda control able to run Lambda 1 on full load all the time even when fuel smoke mapping is optimised so yes happy on that part as well.
[url=http://www.youtube.com/watch?v=fxSmAJHh7U4]www.youtube.com/watch?v=fxSmAJHh7U4
[url=http://www.youtube.com/watch?v=K4IYnWVTz20]www.youtube.com/watch?v=K4IYnWVTz20
[url=http://www.youtube.com/watch?v=PTsB7F8L5oE]www.youtube.com/watch?v=PTsB7F8L5oE
[url=http://www.youtube.com/watch?v=4LBOwUq_o2I]www.youtube.com/watch?v=4LBOwUq_o2I
[url=http://www.youtube.com/watch?v=hLLgT48aYjY]www.youtube.com/watch?v=hLLgT48aYjY
[url=http://www.youtube.com/watch?v=0MGyFPofH30]www.youtube.com/watch?v=0MGyFPofH30
What a Truck Race weekend @ Brands Hatch this weekend.
First of all congratulations to John Powell running B division with his DAF having a Cummins ISX12 engine. Think he leads B division championship now. As last year on Brands Hatch he dropped a valve looking for better parts having good endless conversation with him coming out on top. Just great. Never give up.
Adam Bint. My local support hero helping me out online with some Gramlings after first time this year of race teams running there engines on track. Many thanks from me. Not the best of luck for him on track. Hope next race event he has more luck. He deserve it.
As for Division Truck Race. In total five D26E6 race engines out this year having podium places in every singe race even a podium lockout in race 4 with Stuart Oliver and newcomer to A division Bradley Smith and Ryan Smith having the lead after this race weekend in A division championship but yes still many race events to go and anything can still happen. That’s racing big stuff.
[url=http://www.youtube.com/watch?v=52vYcnhSsM4]www.youtube.com/watch?v=52vYcnhSsM4
2022 version of MVJ2 Semi Truckpuller. Load have changed saving a lot of weight with thinks like removing the original steering box going to a all hydraulic electrical steering system and load of other things as well.
[url=http://www.youtube.com/watch?v=StDxZNV0aU0]www.youtube.com/watch?v=StDxZNV0aU0
First test pull after all modifications done.
[url=http://www.youtube.com/watch?v=3qspK-uOmL0]www.youtube.com/watch?v=3qspK-uOmL0
This a is DAF truck Called Daffy and it has a Cummins QSX 15L Commonrail engine it it.
Last year we get a bout 1100 to 1200Hp out of it and this year we fitted 30% bigger injectors and a bigger fuelpump as well and both parts are drop ins as well so your able to install them on a original engine without modifications.
[url=http://www.youtube.com/watch?v=iNWl_eDltjY]www.youtube.com/watch?v=iNWl_eDltjY
As you know on most project we not going stupid on the amount of fuel injected but we aim for efficiency. We now run just under 3 Bar boost pressure and still able to gain over 30% more fuel pressure that will up the power a lot more. We had to stop testing due to that the turbo was leaking oil into the turbine housing.
[url=http://www.youtube.com/watch?v=qtFHMBOT5ho]www.youtube.com/watch?v=qtFHMBOT5ho
This also top sport with no excuse and the picture shows that these Race engines run on there limits.
Reliability what about it? We build race engine that last less than 20.000Km between a overhaul where a other engine type do easy over 150.000Km. Is the engine type that dos less Km less reliability? Not really it only needs a different maintenance interval to keep it up and running.
So what is the story? All truck race engines we build are based on normal engines used for commercial road transport and on a normal rated performance level run a normal service live and it’s only when you up the performance level things will chance. Low engine weight and compact size means less material and space inside the engine bock simple means more sensitive to thermal stress and flexing where other engine types @ more weight and bigger size they are better up to the job running hi performance levels even running special original engine parts that support the performance level better.
Top sport is not all about budged is about the best for the type of motor sport you want to participate in. Some motor sport project are engine brand related and if this engine has more weight and size we simply have to get smarter by making it more efficient as there is no excuse to top sport performance under performing. Know how and stay focus on all aspects to make improvement.
Testing a Truck Race engine ready for the race circuit.
Some of the specifications.
12.4L displacement. Power output in this engine configuration 1160Hp 5300Nm @ 1350RPM onwards but with a bigger fuelpump and turbo we can easy make >1250Hp 6000Nm with same spool-up form turbo as this engine configuration manly due to more modern turbo used.
Than we have the FIA European engine spec with a 63mm inlet restrictor 1120Hp 5300Nm or 1120Hp 6000Nm more low end power as max power is limited by inlet restrictor size,
Fuelpump on this engine is a CP3 hi flow limiting Nm but with a adaptor plate we can fit a lager CP9 fuelpump and have the fuel to make 6000Nm. With the engine development we went for a modular design so we can always upgrade or even downgrade the engine in performance by changing parts.
[url=http://www.youtube.com/watch?v=XLCExy31BIA]www.youtube.com/watch?v=XLCExy31BIA
[url=http://www.youtube.com/watch?v=-Oo7Y5SJLYc]www.youtube.com/watch?v=-Oo7Y5SJLYc
Without data no gain on performance you could say. Modern engines are complicated and so many things have to work perfect together to get the max out of your engine.
This software can do a lot more than only read data from a Baldur ECU. It can also read CSV files and I can handle a load of it even live if needed during testing. It’s software like this that gives us the edge to wining races and that why we use it. Best of all it free and get your sample here https://controls.is/calibrator/
Other note and think about this. If an ECU manufacturer charge you extra for better data acquisition software what are they thinking? Your stupid and we are smart and we can help you getting smart? I think it’s they opposite if you build the best and work with the best teams you have to stay the best and how can a ECU manufacturer know what you need if you build limits in the software in order to gain more profit from your product. Clearly always a step behind doing this as they simply will be your limit on things so move on and find something better that you can build into something that you need. Baldur ECU is clearly on the same page as we are and in the software we can make our own calculations on what we need on data and you as a customer will benefit from that as well.
Data tells the story. This is from a B engine so no waste gate and limited on torque as the fuelpump is on the max. We also build A+ engines with a bigger pump and smaller turbine side or better say low inertia turbo with an external wastegate and this spools a lot faster and with a good driver that makes max torque @ about 150 Rpm faster so from about 1400Rpm for a B engine and A+ engine makes max torque @ about 1250Rpm and able to make 6000Nm as the B engine can do only 5300Nm max. @ low end you can gain some power this way with an A+ engine but as you can see in the power curve it’s almost flat so this 63mm inlet restrictor dos it job well. Also note that getting 6000Nm of pulling power on the tarmac is close to impossible as only the multiple champions of truck racing can handle this as for intense traction control by accelerator peddle and from 60kmh only last gear is used and that’s almost the whole race track as you can power slide even a B engine @ 120kmh no problem but this just makes things slower so when we have to assist an new comer to truck racing most effort goes in to power management from the driver. We sometimes take 30% of the torque deliver from the engine just to make a point that the driver is slower having max engine power as track time indicates this.
As for RPM there is no point going over 2500RPM as we can only run 160kmh and that a hard speed limit but the engine has the speed governor set @ 3000Rpm.
As for next year the FIA organisation also looks for low lambda reading to prevent smoke. I do not think it will work the way they plan to take the lambda reading as it unfair for us using last generation engines that are able to make more low end power @ lower lambda numbers with no smoke @ all but as you can understand running on low RPM gives less exhaust gas volume @ that point and the rule is lambda 0.96 for 0,5 second is a penalty. So all development we have done goes to waste as the downside from a last generation engine is it runs more efficient not making a load of exhaust gas volume so these engines run a smaller turbine side with a wastegate and more low end EMP to get the job done. More EMP also makes more EGR working in the engine mainly due to the effect of turbo surge when off power and breaking going from off power to on power @ low RPM you get a low lambda reading for some time as exhaust gas speed is relative low @ low RPM. Looks when no combustion takes place exhaust gas gets trapped in the system somehow as well. we will run our test and come up with a solution for this.
Lambda reading
Torque reading
Power reading
thanks for your posts , always interesting
seems such a small hole to make that amount of power
what are these engines revved to ( rpm ) ?
The Dakar has been a must follow for a long time , and the trucks are a spectacle that never fails to entertain
I get some question about lambda in relation to EGT. The best project we have for this to come to a conclusion is the modern Euro6 Volvo D16 common rail motor based on the 750Hp truck engine. On this fuel set-up we have plenty of fuel and we are able to smoke and run the engine from lambda 1 to over or lower than 0.88 lambda. The outcome is that these modern engines make the best power around lambda 1 and this will get the EGT up as well. The lower we go on lambda power and EGT drops as well and so dos EMP and boost pressure.
Now here is the thing if you build an engine that dos not work close to perfect all of they above can be different so take that in mind. A other very important thing is fuel injection pressure. Last year we had big problems on a race engine with fuel contamination throwing the whole fuel system off balance. No smoke no power loads of boost pressure but bit down on fuel pressure. Trick is for making big clean power is that fuel in on time getting that massive thermal spike going in the combustion chamber. If the fuel injection is extended to far due to bad constructed injector with slow injector closing time due to bad nozzle to valve balance or to low fuel pressure your combustion is more dedicated to the exhaust system shooting up EGT making good boost but less power. We use all steel pistons in all race semi truck race engines. Correct me if I’m wrong but I do not think a alloy piston will last long running full power @ around lambda 1 as things in the combustion chamber will get very hot and also last year we had a prototype steel pistons fail due to cracks and eventually on of the piston blowing a hole in the piston dome due to this. Modern diesel engines well build lean toward petrol engines if it comes to lambda numbers.
Below some pictures for the FIA 63mm air inlet restrictor plate. If you get this 63mm inlet restrictor hole working well your looking @ about 1100Hp power output so a bit of engineering needed on these parts.
To bad game over for Dakar Speed Rally 2020 after this crash. Crew is OK and they dit finch the yesterday stage on a 28e place even but the FIA safety officials concluded the role bar behind the cab needs to be replaced and the team did not have the given time to do this.
Next up is the evaluation. Engine seems to perform well but as always there is always room for improvements.
The part that failed yesterday costing them over 15min as they had to slow down.
Impression on maintenance during the rest day of the rally.
https://www.facebook.com/Dakarspeed2022/videos/496036422051465/
Still holding 9e place after half the Dakar Rally so I’m happy. Tomorrow the team has a rest day, well one day to do all maintenance needed on the truck.
Surfing the sand dunes.
Jump nearly go wrong Dakar Speed Rally 2022 day 4 of rally
We done it on day 4 of the Dakar Rally. From 9e place to 5e for most of the special stage but a leaking tyre throw them back to 7e place on the last part stage time for the Semi Trucks.
Overall they now in 8 piston and goal is to end this rally on a top 5 spot but this rally is very long and loads of things still can go wrong. Also take in mind this is professional motor sport with loads of teams having factory support and we are part of mixing in this game. Smile.
Trucks in Dakar had always been my unfulfilled dream, to compete that is. My admiration does to anyone involved.
Re. privateers not having an experienced engineer to monitor engine data, have you/they considered doing remote monitoring? In my regular life, I maintain a lot of satellite communication equipment. As a backup for access in a worst case scenario, it being full communication blackout, we utilize an L-band turn key solution, provided by Inmarsat (made by Thrane), under the name of Fleet Broadband 250. It offers voice and data, to basically any remote location in between 70deg North and 70deg South. I'm not privy to costs involved, but for a racing team it may be well affordable. Transceiver of the FBB250 is a small-ish cylindrical object, perhaps 20cm in diameter and same amount in height. Unit is made for marine environment, so it's tolerant to rocking and rolling. I think it would survive the harshness of driving through the desert.
Sounds like a plug, but it ain't, I promise. :) I don't sell the gear nor subscription, nor am I paid by Inmarsat. I just see an opportunity to share my experience, and if that helps any team competing in Dakar, I'm happy.
The point is, you could have live access to engine data, perhaps with a second or two delay, and you could support the team from your home. There are also more compact solutions, aka handheld, like Iridium (I think used to be built by a Nokia), but I'm not sure of their data capabilities. Iridium was used in the original Dakar Rally by some teams, so proven it's worth. Albeit, for voice.
Great write btw, thanks for sharing
Day 3 of the Dakar Rally 2022. The team is getting up to speed hitting a 9e place on the rally stage today and 12e place overall in Truck class. This is top sport and if your not on top of the game your losing time.
Team Dakar Speed is a amateur team as they build the truck them selves were all other top teams have factory support or a large teams of professionals work all year on the rally trucks.
So what is the difference? For the most parts time spend on running the rally trucks and maintaining them. The professional teams knowing all systems having the routine and this is not possible with a amateur team so how can you make this work the best?
The key is keep it simple. I’m a professional engine builder and with a bit more time spend I can up engine performance and this can complicate things as more monitoring is needed for example. The team dos not have a expert on reading engine data and there focus should be get the truck ready for the next day best possible so key is to find the balance between performance and engine parts used where less is more. The good things is the Scania XPI is a very good and efficient engine and as for this year there are upgrades to the fuel system planed for truck racing and if we have this data we can implement these on the rally engines as well but as always we need to test them and for this rally truck build the coolers could be the limiting factor. We still could go up in coolant temp even up to 110 degrees C but than coolant pressure should be monitored a lot more as this shows coolant flow or coolant flow drop due to pump cavitation.
Some impression on what this rally is.
The Dakar 2022 Pre prologue is done for Team Dakar Speed. I see it as the last general test for what is yet to come. Hard driving through a pile of dust to make up for some places and we succeeded from 23rd to 12th place to start the rally tomorrow.
This is the part inside the injector that makes it all work. On top there is the solenoid operated valve and on the bottom end the injector needle that closes the nozzle holes. Open the injector valve and the pressure balance changes inside the injector and the needle start lifting on the nozzle end. If you fit a nozzle with more fuel flow this changes the pressure balance inside the injector and this needs to be balanced with a this part you see on the picture and this makes the injector react more accurate on opening an closing and reduces return fuel from the injector as well.
Lets talk about engine management. Not only the engine management system but as a total project.
Lets start with the ECU or ECM or just how you want to call the engine controller.
We use aftermarket ECU and there are loads manufacturers out there saying we provide the best platform. There is no best platform as we keep improving things all year in a ongoing process. It’s just a mind set that dos it all like Kaizen for example and this is what I use for processing things.
Well let’s look what is needed to gets things working for me on ECU systems. 50% is dialling in fuel for different fuel types from normal pump diesel to HVO or GTL that have a different viscosity and cetane number and this is a job that needs to be done normally begin of the year after changes by the race organisation on what fuel can be used only. The rest of the 50% are changes that involve control strategy writing new code to change the behaviour on rail pressure reading or response or torque build-up. So in all you end up with a simple 35x 2D tables and 57x 3D tables to get the job done and I customise the logic between them on how strong the power comes on. May sound strange but a less good drivers is more demanding on that parts than a multiple champion that is able to control traction and able to multi task.
Now for the fuel system. Performance by efficiency. I know I keep saying this. For an example there is this man in France that dos some lower ranking race teams and he is able to get 14% less fuel injected on the same fuelpump configuration. In fact in total he is 26% down on torque but that’s due to the different fuelpump drive we use running more pump RPM. So where dos this 14% more fuel come from?? Difference is injector set-up. We chance the valves of the injectors giving less internal leak and more accurate opening and closing of the injectors. If you bay a 100% over stock injector you know most are crappy injectors as only the nozzle hole size and maybe the needle lift is changed and you run out of fuel volume from the pump very easy and chance is if they spend some more effort on these bigger injectors you will make more clean power with a smaller injector still using the stock pump having better fuel economy.
I also know getting the correct valves made is close to impossible so on these parts we are lucky that the diesel industry is able to help us out on R&D volume rate things. Not really low cost but we are out there to be the best.
For next year ongoing build of D26A6 race engines and yes we have the order in to build one more massive power house D26E6A+ engine able to run over 6000Nm of toque. Big fuelpump and loads of modifications needed to support this fuel system. On engines like this we have to work as a combined team between companies to get these special parts.
Also to some this may sound strange is what you do and don’t do on modifications. Changes that we make on engines parts like cylinder head are very small but have a large impact on performance.
I think still the most epic looking Scania powered International Rally Truck.
Upgrades to the engine this year. Not a lot. Inconel exhaust system and a bigger downpipe and silencer to reduce backpressure. Last year exhaust system was a compromise with the team as for having no space to fit these parts and result is lower boost pressure as the ECU reads exhaust manifold pressure and reduces boost pressure as a result.
https://www.facebook.com/martinmacikjr/videos/1339707366483717/
Great job on your engines, congrats for the winnings. Looking forward to seeing the Dakar results.
Thanks for sharing
