Link g4+ Atom on normal distributor engine ( Dizzy)
Diesel Tuning Fundamentals
Good day every body,
I am starting to install Atom G4+ unit on toyota 4efte engine which has a distributor ( dizzy), so my qustion is how to wire the crank and cam sensors on this engine? If there is any wiring diagram because i found many diagrams which people wires these sensors through the oem ecu pin out but i want to make independent harness for this engine
Kind Regards
Khalifa
The 4EFTE should have two sensors inside the distributor. one will have 24 teeth which is the rpm or Trig 1 input. There will also be a single tooth input which is the sync or Trig 2 input. There are however two pickups for the sync input and you can choose to wire Trig 2 to either (it doesn't matter which one but you must only use one).
With a reluctor pickup it's important to get the polarity correct and with Toyota's wiring normally the 0V is a white wire. You can trace this to be sure though as you will find it is common to all three sensors in the dissy.
