Shielded wire run inside main harness
EFI Wiring Fundamentals
Are you about to run shielded wire inside the main harness or does it need to be separate? I have a VR sensor and Coil pack that has 3 wires running to it for ignition. Can they be inside the same harness?
Yes - I do this all the time.
