Discussion and questions related to the course EV Fundamentals
Good Day
I’m having Issues on my 2JZ, I recently changed the Cylinder Head, from Non VVTi to VVTi, with that, I added the VVTi oil feed to the engine block, and changed the Crank timing gear to the 36-2.
My Engine was working on 5º TDC angle with the Non VVTi head.
So I changed to the Haltech default 2JZ GTE VVTi standard settings, But the Car starts Roughly.
The Car works more or less Ok when I put on 475º on TDC Angle.
I’ve attached my settings picture
Can anyone Help me with This ?
Are you sure it's 36 - 2? 36 - 1 is more common for 36 tooth wheels.
You should use a timing light to verify the TDC angle. Should be easy enough to do if you car will start / idle.
Yes, Im Sure it’s 32-2, It’s the Standard one for 2JZ, even the Haltech gives that option as standard..
I tried the Timing Light, since I got the Car to Idle very Bad, on 515, and the Timing is sitting on 10 on the Crank, and on the Cams is sitting on the Centre..
I don’t understand what I’m getting Wrong.
Timing is locked to 10* degrees for that test?
I'm not surprised that the timing offset is much different then with the Non VVTI trigger wheel, as it doesn't have a home other then the cam.
I'm sure you've watched this video already but just in case, here's a video from Haltech explaining how to set timing.
