HP Tuners from one truck to another
EV Fundamentals
Discussion and questions related to the course EV Fundamentals
Hi I have a quick question. Is it possible to use HP tuners to copy a tune from one truck to another. The reason I ask is my brother and I both have the same truck. 2018 f150 with the 5.0l coyote motor. His truck has the TSB install which is a PCM update that fixes misfires and stutter in our trucks. Mine does not have it an the dealership is saying 6-8 weeks before they can get me in to apply it. I was wondering since my brother's truck has the correct PCM update, can I just copy the data from one to the other. If so which tables should I copy over. Obviously I would not need the entire tune, but which parts is specific to the fix?
Thanks
-Barry
Why not start with utilizing the compare feature in HP Tuners? That will show you what tables are different then you can decide if they are relevant to your problem.
