Splicing to Shielding Braid
EV Fundamentals
Discussion and questions related to the course EV Fundamentals
Why splice to shield braid and not just connect shield braid direct to ground if possible? Is that wrong?
It all depends on the shielding. Sometimes, I can de-braid, twist it to look like a wire, and put sheathing over that and crimp the result in a terminal. Other times, I need to splice to it (and maybe other shields together) and use a short section of conventional wire.
Okay, so its more what´s best for the aplication then? Because i have done like you described and twisted the sheild and put sheathing and a ring terminal
Yup, I'd agree that either is fine, and I've done both, but splicing the shield to a piece of wire, and then the wire into a connector is going to work every single time, whereas it'll totally depend on your setup / strip length as to whether you can crimp a terminal directly to the straightened out braid... I like to have a known, planned solution come build time, so I go for the splice to a wire method :-).
