I'm trying to better understand how the left front spring rate affects roll stiffness calculations for a left-turn-only car equipped with an anti-roll bar (ARB).
In a left turn, most of the load shifts to the right side, compressing the right spring. This compression also twists the ARB, which in turn acts on and compresses the left spring.
A stiffer left front should loosen the entry up and opposite for a softer spring. A stiffer left front will produce more roll angle to the right and more load on the ARB which is why softer spring setups require a stiffer ARB. The front springs and ARB contributes to the overall roll angle/stiffness. So it should be included in calculating roll stiffness especially if you preload the bar. The ARB also try’s to pull the left front up, not compressing the left front due to the right front compressing and pushing the bar upwards. I hope this helps some?
Hello Jacob, thanks for the response. What do you mean by “pull the left front up”? Perhaps I’m misunderstanding ARB mechanics, but for example, if I had a super stiff bar with no flex arms, wouldn’t the RF compression go all the way through the bar / arms to the LF and compress the LF spring effectively lowering the left front frame ride height, hence the reduction in roll?
You would be correct about that. I interpreted what you said incorrectly. So yes, it would try to compress the left front spring by pulling upwards on the left arb linkage since the arb is usually attached on the right side which under compression would push upward on the bar.
This question is stemming from the HP Academy LLTD Worksheet. The input for Elastic Stiffness front values is Front Spring Stiffness and Front ARB Stiffness. If we make the assumption that we are calculating for a left-turn-only car, how would you factor in the affect of the LF spring? I'm using the RF spring rate as the input value for Front Spring Stiffness, but after thinking about it, that seems to be missing a significant factor that the LF spring is contributing to the overall front stiffness.
Any insight on calculating and including LF spring's roll stiffness contribution -- thinking you'd need to do something like: (LF spring rate / motion_ratio ^ 2) and then adjust that with some kind of an ARB twist fudge factor? Or maybe just simply tweak the Front Spring Stiffness input value with an educated guess on a combined / adjusted RF and LF spring rate?
Interesting question and one that the current spreadsheet isn't set up to address since the assumption is that the the spring rates are matched left to right. Short of redeveloping the spreadsheet, my first thought would be to enter the average of the left and right spring rate. That should give you a realistic idea of the overall front roll stiffness.
I have often used a stiffer (10-20%) right rear spring to "free up" a car that runs on a big oval. So I would be pretty sure that running a stiffer Left Front spring would have a similar effect -- but would interact with the Front ARB to reduce the roll and keep the front splitter more level for aero purposes.
Okay, thank you for the replies. I'll mark this as resolved.
