Time delay and catalytic converter
Hello I just wanted to know about expectations of from a steady state rpm to a time frame from Tp open to semi closed throttle in open loop time to closed loop and also the times for a delay for the AFR to lean out with a o2 sensor approximately 600mm from the last exhaust port when closing the Tp to work out if I have to much acceleration enrichment and the expected lambda richness from around .85 lambda to Tp closing for next gear example from around guessing around from a 4000rpm point downward in Rpm
It’s a Mazda RX8 with a cat temp of around 1575f 900mm from the last exhaust port if it makes any difference?
Thanks have a good day?.
