Wideband compatibilty
I have the MPVI3. Is the AEM x-series 30-0300 compatible with a 2005 Yukon? Or do I have to go with the Ballenger AFR500v3?
hello there,
The HP Tuner Prolink add on for the MPVI3 has 2x 0-5v analogue inputs so you can use any wideband controller or gauge that has a 0-5v output so either of those listed will work. The Prolink also has CAN so you can use any number of lambda to CAN wideband controllers too and still keep the AIN for additional sensors.
Regards,
Scott
