Camber/Caster gauge wheel adapter
How to Degree a Cam
Hello,
can you show in detail your wheel adapter for the camber/caster gauge?
Thank you for your attention.
Hi Hugo
I'm not sure exactly which adapter you mean as there are a few options, but I've included a screenshot from the Wheel Alignment course (Measuring and Adjusting Camber module) that shows the adapter that locates the Longacre bubble gauge. This is machined to fit the inner ring of the wheel and/or hub very closely. It's also made from steel so that the magnets on the gauge stick to it.
Let me know if you have any other questions on this!
Tim
