Using the 2 Step with less pops and bangs?
How to Degree a Cam
Hi Guys, I'm using a fueltech 450 on a Toyota 3sgte motor....I am trying to reduce the pops and bangs...if I'm getting the desired boost can I add or reduce fuel to have it pop less? I've been hearing cars with the same system building boost and no pops and bangs...can you assist? Thanks
Using fuel cut rather than spark cut will drastically reduce pops and bangs.
Less timing retard will also reduce pops and bangs.
Fuel can be a factor, but I suggest keeping fueling safe and make your changes elsewhere to tone things down.
