cutoff backfire
Launch Control
hi
how i can make backfire at cutoff with link atom ?
You'll need to make sure over run fuel cut is disabled for a start. From here it can help to retard the timing slightly on over run and add a little additional fuel.
Sorry I can't access that link. I'm going to need more information about what you're trying to achieve. I'm not sure what exactly you mean when you say 'backfire at cutoff'
Under the engine protection tab you want to select 'RPM Limit',
RPM Limit mode - Ign %cut
If that's not enough you need to proceed with caution and activate the advanced mode.
@chris250
yes i use this mode .. but i need something more aggressive ... do you have a specific setting on advanced option ?
@Andre
for myself i'm interessed to make bang like in follow link, with the same engine (it's a naturally-aspired engine)
https://www.facebook.com/819010031552316/videos/1349286601857987/
@Andre
