ALS Valve on Link g4x
Motorsport Fabrication Fundamentals
Hello guys! I have this tibuc als valve on a evo!
The valve has a servo inside that regulates the amount of opening on the valve inside.
Can i wire this valve straight to the ecu? As the «stock» tibuc controlbox is dead. the stock box only adjust & of valve opening
The valve only have ground, +5v and signal
can i wire it via sensor 5v/gnd and to an AUx port?
Link g4x evo9 pnp
I'm not too familiar with the Tibuc brand but it just looks like a throttle bypass valve, you could replace your idle valve with this and use the ISC override to control how much ALS you wanted
I would not power a servo using your 5V sensor power source. It can drag the voltage down, throwing off sensor readings.
hmm, if it helps you guys. this is the servo inside. https://servoshop.co.uk/index.php?pid=MG996R&area=Servo
its basically a throttle bypass valve yes
