I am looking to find out if anyone can help me find the part numbers for these 2 connectors. I have looked on Octopart, Mouser etc... Can't figure out which one they are. Any help would be appreciated. I need to replace these and need the pins too.
Also Color does not matter. I have the Grey one in white as well... and the white one I have in blue as well. Function over form in this case lol.
94 USDM RX7 (FD3S)
Brand - Part Number - Links - etc would be amazing
Thanks - Paul
The first one has an odd housing but those look like TE Multilock 070's. If the black connector interfaces with the 14 position socket on the stock ECU you're golden. The 12 position also looks exactly like a Multilock. Might want to give these a shot:
Edit: Ugh, link syntaxing is garbage on this forum :P they still click at least.
Thanks! The Miltilock 070 series is winner
No probs, I dig what you guys do with bringing FDs in the States back to life.
@M:EP thanks. We try and do it with pride and quality. I found the connectors thanks to you setting me on the right path. What was confusing me was the aftermarket connector I was starting the search with. Once you set me on my path I looked at the stock harness and saw that the rear of the two connectors were the same.
Thanks again and thanks for the kind words. We strive for excellence.
Paul @ IRP
