Hi Guys
Just installed an elite 1500 on my fc rx7 13b turbo.
Everything was going smoothly until initial start attempt.
Car has no visible spark yet enough to make timing light flash and it comes up with DTC code PO373 engine position error.
Using the onboard scope I can see the triggers working.
The map loaded was from my mates car (exact same engine/injectors/ turbo setup ) but his is cdi and mine is ign1a just wondering if I have missed a setting that would be used for a cdi and not ign1a.
Any help would be much appreciated I'm new to the elite platform
Gareth
Haltech terminology is probably a bit different but check Spark edge is set to falling, and Dwell mode is set to ms/time/constant charge or similar.
Otherwise you should attach a log, tune and scope file if you want help from someone more familiar with Haltech.
Any update on this?
Resolution
It was a combination of a dieing battery and starter and also the main engine to body earth wasn't properly cleaned at the point where it bolts onto the engine (fresh paint)
Cheers for peoples info
