Fine tuning Ignition on Road
Practical 3D Scanning
Discussion and questions related to the course Practical 3D Scanning
Hi guys,
sorry to bring this up, i am tuning on road always, i am using haltech ecus, so in ignition map tuning on road, shall i advance ctrl+a map then i start advancing timing by 1 or 2 ? Or only advance the timing in last 3 rows of load? Regarding the fuel its fine because each run i am datalogging and using o2 input for ease adjusting using quick tune Q. Is there any phone app or device to measure G force each run during tuning ignition map?
For boosted engines i have same question regarding ignition advance, increasing timing at non boost area, then -2 degree per 20kpa??
also if i hire a dyno and its a non eddy current dyno, how to tune ignition on this dyno? Advance all area of the map or only last load area?
i am little confused in this part, what about middle area of ignition map for NA engines and boosted engines also?
thanks in advace
Can you please post a screenshot of the timing map you are looking at and give us a full list of engine specs including compression ratio, any kind of aftermarket camshaft, etc and fuel octane you are running?
There are definitely rules of thumb to help you but if you can post a datalog if you doing a WOT pull and post a screenshot of your timing map it would help a lot.
Dear Arghx7,
thanks for replying
please find attached screen shot of turbo ignition map road tuned
engine is toyota 4efte , 8.5:1 compression, 98octn gasoline,550cc injectors, boost 0.8 bar
any advice and comment will be highly appreciated
4500rpm and up needs some work in boost. At lower boost you have fixed timing from 4500 up, at higher boost it is advancing but not in a smooth way. Try tsking the 4000rpm advance ans adding a degree every 500 rpm, or even be more conservative and add one degree every 1000 rpm.
