Discussion and questions related to the course Practical Corner Weighting
Is the wideband sensor replace the OEM one or is installed next to it in the exhaust pipe?( if it is none portable )
Is there straightfoward wideband O2 sensor plug-and-play replacement?
There are wideband sensors with gauge that got the narrowband output (0-1V). If you are going to replace OEM sensor I'd get one of those with narrowband output and connect to the ECU.
