2JZ ACL con rod bearing question
Practical Diesel Tuning
I'm just doing final assembly on the con rods and I've noticed that the the locating tabs on the ACL bearings (6B8100H - STD) actually allow for some 'play' on install in the rod and cap - meaning that it's possible to assemble the bearing slightly off-centre by a small amount if you weren't paying attention. I've checked the bearings that came out of the engine and they are exactly the same. I can obviously centre everything on install, it just struck me as odd there was this play available (it's a very small amount we're not talking about loads) so I wanted to check this is normal. It looks like it might just be part of the process for how ACL make the tab - it kind of 'cuts' the outside edge in a bit. I've already dry-assembled and checked oil clearances - absolutely everything is spot on, standard con rods.
Cheers!
It's not uncommon. I personally try and centralise the bearings but if there is a slight misalignment between the upper and lower shell it really won't affect the operation or reliability.
