DTC P0605 delete
Practical Reflash Tuning
I tried to flash my ecu and dtc p0605 came up. How can I delete that code in the ecu? Can i do it through the VCM Editor? Or is it in the VCM Scanner? Thank you
P0605 is an internal memory ROM error which isn't one I've come across. It could be a problem with your ECU or it may be related to your flash. I'd be inclined to clear the DTC and see if it reappears. Failing that I'd reflash the ECM and use the 'write entire' option.
