Electroninc boos controller
Practical Reflash Tuning
If am gonna reflashy evo x mr stock ecu..... but ive already fitted GFB elctronic boost controller..... is it ok to tune the fuel delvery n ingnition timing tables ???? Or the is any measurments should i take to consider the controller?
Theres' no real downside with using a standalone boost controller and reflashing the factory ECU. It's no different than running an external boost controller on an aftermarket ECU. You will need to make sure that you tune at each of your desired boost levels and log to find where in the maps you're running.
