Excel spreadsheet
Practical Reflash Tuning
Where did the excel spreadsheet come from that was used to convert the ve table for the sd operating system
In the SD worked example? That isn't a pre defined spread sheet. I simply copied the entire VVE table and pasted it into excel, then copied it again and used the transpose function to flip the axis. Do you not feel i explained this thoroughly enough?
Ok I see what you did and yes you did explain it good as far as what you were doing and how to do it but I wasn't sure where u you got the spreadsheet from. But now I understand that u just copied and pasted it right to it. Thanks
