Step 5-C: Steady State Tuning and Live Tuning
Practical Reflash Tuning
In this video during the cam tuning, the wrong surrounding cells seem to be selected. The cam sensor is registering 22 degrees the entire time because it's interpolating between the 29kpa and 41 kpa columns, and you have the 41kpa to 64 columns selected for changes to be made. From what I'm seeing, the 29 kpa through 52 kpa cells should be selected instead. The CAMCMD is staying steady at 22 degrees even though you've made changes. Or am I missing the point?
Yes, there was an error with the particular piece of footage that was edited into this step. We are intending to reshoot this. For now the description of the process is correct, even if the demonstration isn't really illustrating what should happen.
