Mass air flow calculation
Understanding AFR
Calculating mass air flow at a certain rpm at WOT on a naturally aspirated engine, assuming that the VE is at 100% to approximate the injector pulse width for a starting point is simple.
But is there a way to calculate the mass air flow or VE at a certain manifold pressure where the throttle is not at WOT (cruise) or when there is a overpressure (boosted engine)?
Air density would change, that can be calculated fairly easy, but the mass air flow?
It would be awesome to calculate that for a starting point and then adjust while looking at the lambda.
I built a spreadsheet that would calculate Grams per Second with "knowns" and some "assumptions" when I worked at Identifix (Automotive Technical Hotline for professional Technicians in the aftermarket).
https://docs.google.com/spreadsheets/d/e/2PACX-1vRG0AcwTMfyHGbG9fiJbPEmhIDt0W6SJsk7I5EMaH9454q3ilrgYjT1YpDg1-s3QOUFq7dhvsSPryyk/pubhtml?gid=0&single=true
Engine Displacement in CC
Engine Displacement in Cubic inches
RPM
Engine Vacuum
MAP Absolute
Barometric Pressure
DR
Assumed VE
CFM
g/sec
Lb/M
Kg/h
3500
214
715
20.5
9.1
29.6
0.307
0.75
10.18
3.96
0.5234
14.24227779
3500
214
2500
23
6.585131579
29.6
0.223
0.75
25.79
10.04
1.3265
36.09496747
75% VE
Varibles to be adjusted are in Yellow
G/Second reading you should see on the scan tool
Assumed VE
Calculated values
75% VE WOT
3500
213.6
7000
0
29.9
29.9
1
0.75
324.45
126.27
16.6873
100% VE
3500
213.6
6000
0
29.9
29.9
1
1
370.81
144.31
19.0712
Corrected Baro
30.1
Altitude in Feet
500
Baro Correction Factor
0.982894737
75 EV
100 VE
UnCorrected Baro
29.58513158
Calculated Load?
0
0
How can I edit or put new values in that? Excel?
