traction control
Understanding AFR
IN Full-power condition is there any need to turn traction control to off mode
I have a customer with an LS3 swapped BRZ. I find the car practically undrivable without the traction control. He can't stand it. He wants to spin the tires and slide the car.
I want to bury the throttle at every opportunity.
So it depends on your driving technique. That is why traction control enable/disable and the slip allowed needs to be adjustable by the driver.
but in the tuning process is it must to be off
Yes, you can't test on the dyno with traction control enabled on most cars.
