Volume Formula in Engine Principles video
Understanding AFR
This may have been mentioned before but there's a slight mistake with the mentioned formula that you used in your example. Shouldn't it read V = (3.142/4) * (bore*bore) * stroke? Your example missed the division of Pi which explains why I kept getting 201.08 as my answer.
There should be no division of Pi.
To work out volume, let's start with calculating the area of a circle.
Area is calculated by Pi x radius^2...(the ^2 means squared)...and the radius is half of the diameter. The diameter is the bore in this case, so radius would be 2 inches
So the area for that example would be Pi x 2^2 = 12.5675
Volume is simply area multiplied by the height of the cylinder (the stroke)...so volume = 12.5675 x 4 = 50.27
Where they did make a mistake, however, is when they filled in the numbers for the equation and put r^2 as 4^2.....it should be 2^2
