Water pump control
Understanding AFR
Relevant Module: Certificate > Request Certificate
I was surprised that your water pump control in the above tutorial was only table based and had no “and” controls. I would have thought as currently programmed the pump would run at its PWM table based speed as soon as power was supplied to the PDU. Shouldn’t you have it maybe start in “enabled mode”, or even start when engine speed exceeded 600 rpm? And then add a run on mode once “enabled” power was removed for 10 minutes at a reduced speed.
