Got a question regarding adjustment of the ford timing tables (mapped points 0-4). If I adjust these tables to effect timing will I then have to tune the torque tables? Now the vehicle is stock other than intake and full exhaust and I can see the ecm is adding torque under WOT. So I was going to add timing in the respected areas, but after watching the practical reflashing on the 6.2L ford raptor I'm a little confused as if I have to tune the torque tables after a timing adjustment. In the reflash video the torque tables got adjustment but I believe that was due to adding the supercharger. My IPC error is well under 25 so as the vehicle sits the torque tables are spot on. Thanks in advance for any advice
