Ignition mode/trigger angle
WinOLS Mastery: Map Identification & Editing
Discussion and questions related to the course WinOLS Mastery: Map Identification & Editing
Novice here,
I own a an Evo 9 with Haltech platinum pro PNP. In ignition set up, the only selections I have is Waste Spark and CDI Single Wire IMS.
What do I select if I’m running a coil-on-plug?
Second is that, as I watch you on the Trigger section, I noticed that I don’t have the same selection, it only “Trigger angle.” Is it the same as the “TBD Trigger Offset Angle?
